[GRASS-QA] GRASS QA: markus | ./grass6/display/d.rast/display.c |no
	clones | 0 monsters | 1 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Fri Aug  3 12:23:21 EDT 2007
Hello markus,
ANALYSIS
display/d.rast/display.c functions
display (Begins at: 11 Ends at: 65)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      15 |       |      OK |
LOC:          |      55 |       |      OK |
at least 1 values are close to an outlier please consider revising code
cell_draw (Begins at: 67 Ends at: 117)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      20 |       |      OK |
LOC:          |      51 |       |      OK |
metrics are OK
mask_raster_array (Begins at: 119 Ends at: 128)
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-03 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
