[GRASS-QA] GRASS QA: carlos | ./grass6/imagery/i.ask/popup.c |3 clones ( popup.c )| 0 monsters | 2 warnings
Mon Aug 6 11:36:10 EDT 2007
Hello carlos,
ANALYSIS
imagery/i.ask/popup.c functions
popup (Begins at: 40 Ends at: 264)
Complexity:   |      24 |     * |         |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      58 |     * |         |
LOC:          |     225 |    ** | Warning |
at least 1 values are close to an outlier please consider revising code
dobox (Begins at: 266 Ends at: 287)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |       5 |       |      OK |
LOC:          |      22 |       |      OK |
uparrow (Begins at: 289 Ends at: 303)
CalledNBR:    |       6 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
downarrow (Begins at: 305 Ends at: 319)
LOC:          |      15 |       |      OK |
metrics are OK
pick (Begins at: 322 Ends at: 372)
Complexity:   |      11 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      51 |       |      OK |
metrics are OK
draw_which (Begins at: 375 Ends at: 385)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
inbox (Begins at: 387 Ends at: 390)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
outline_box (Begins at: 392 Ends at: 402)
LOC:          |      11 |       |      OK |
metrics are OK
do_text (Begins at: 405 Ends at: 415)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       6 |     * |         |
LOC:          |      11 |       |      OK |
metrics are OK
Clone analysis:
This file has 3 potentially cloned functions:
  dobox  downarrow  uparrow
In imagery/i.ask/popup.c clones of  uparrow are:
	imagery/i.ask/popup.c  downarrow
In imagery/i.ask/popup.c clones of  dobox are:
	imagery/i.ortho.photo/photo.2image/ask.c  dobox
In imagery/i.ask/popup.c clones of  downarrow are:
	imagery/i.ask/popup.c  uparrow
Threshold GRASS6 key metrics values at 2007-08-06 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
