[GRASS-QA] GRASS QA: carlos | ./grass6/vector/v.extract/main.c |no clones | 3 monsters | 0 warnings
Wed Aug 8 12:06:59 EDT 2007
Hello carlos,
ANALYSIS
vector/v.extract/main.c functions
add_cat (Begins at: 36 Ends at: 47)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
main (Begins at: 49 Ends at: 372)
Complexity:   |      39 |   *** | MONSTER |
CalledNBR:    |     129 |   *** | MONSTER |
LOC:          |     324 |   *** | MONSTER |
3 metric are OUT OF RANGE!
scan_cats (Begins at: 377 Ends at: 398)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-08 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
