[GRASS-QA] GRASS QA: paul | ./grass6/lib/gis/parser.c |no clones |
1 monsters | 9 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 8 14:51:51 EDT 2007
Hello paul,
ANALYSIS
lib/gis/parser.c functions
G_disable_interactive (Begins at: 162 Ends at: 183)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 22 | | OK |
metrics are OK
G_define_flag (Begins at: 186 Ends at: 244)
Complexity: | 3 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 59 | | OK |
metrics are OK
G_define_option (Begins at: 247 Ends at: 329)
LOC: | 83 | | OK |
metrics are OK
G_define_standard_option (Begins at: 332 Ends at: 603)
Complexity: | 31 | ** | Warning |
CalledNBR: | 36 | * | |
LOC: | 272 | *** | MONSTER |
at least 2 values are close to an outlier please consider revising code
G_define_module (Begins at: 606 Ends at: 658)
CalledNBR: | 1 | | OK |
LOC: | 53 | | OK |
metrics are OK
G_parser (Begins at: 660 Ends at: 927)
Complexity: | 37 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 75 | ** | Warning |
LOC: | 268 | ** | Warning |
at least 3 values are close to an outlier please consider revising code
uses_new_gisprompt (Begins at: 930 Ends at: 980)
Complexity: | 5 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 51 | | OK |
metrics are OK
G_usage (Begins at: 982 Ends at: 1168)
Complexity: | 33 | ** | Warning |
CalledNBR: | 53 | * | |
LOC: | 187 | * | |
at least 1 values are close to an outlier please consider revising code
print_escaped_for_xml (Begins at: 1170 Ends at: 1186)
Complexity: | 6 | | OK |
LOC: | 17 | | OK |
metrics are OK
print_escaped_for_html (Begins at: 1193 Ends at: 1204)
Complexity: | 7 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 12 | | OK |
metrics are OK
G_usage_xml (Begins at: 1207 Ends at: 1421)
Complexity: | 28 | ** | Warning |
CalledNBR: | 71 | ** | Warning |
LOC: | 215 | ** | Warning |
G_usage_html (Begins at: 1423 Ends at: 1649)
Complexity: | 42 | *** | MONSTER |
CalledNBR: | 85 | ** | Warning |
LOC: | 227 | ** | Warning |
1 metric are OUT OF RANGE!
G_script (Begins at: 1651 Ends at: 1762)
Complexity: | 22 | * | |
CalledNBR: | 46 | * | |
LOC: | 112 | | OK |
metrics are OK
generate_tcl (Begins at: 1764 Ends at: 1859)
Complexity: | 10 | | OK |
CalledNBR: | 45 | * | |
LOC: | 96 | | OK |
metrics are OK
G_gui_tcltk (Begins at: 1862 Ends at: 1891)
CalledNBR: | 8 | | OK |
LOC: | 30 | | OK |
metrics are OK
G_gui_wx (Begins at: 1894 Ends at: 1905)
LOC: | 12 | | OK |
metrics are OK
G_gui (Begins at: 1908 Ends at: 1916)
Complexity: | 2 | | OK |
LOC: | 9 | | OK |
metrics are OK
G_tcltk (Begins at: 1919 Ends at: 1934)
LOC: | 16 | | OK |
metrics are OK
show_options (Begins at: 1936 Ends at: 1966)
Complexity: | 4 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 31 | | OK |
metrics are OK
show (Begins at: 1968 Ends at: 1981)
CalledNBR: | 3 | | OK |
LOC: | 14 | | OK |
metrics are OK
set_flag (Begins at: 1983 Ends at: 2010)
LOC: | 28 | | OK |
metrics are OK
contains (Begins at: 2015 Ends at: 2024)
LOC: | 10 | | OK |
metrics are OK
set_option (Begins at: 2026 Ends at: 2086)
CalledNBR: | 13 | | OK |
LOC: | 61 | | OK |
metrics are OK
check_opts (Begins at: 2088 Ends at: 2125)
LOC: | 38 | | OK |
metrics are OK
check_an_opt (Begins at: 2127 Ends at: 2169)
ParamNBR: | 4 | | OK |
LOC: | 43 | | OK |
metrics are OK
check_int (Begins at: 2171 Ends at: 2237)
Complexity: | 13 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 67 | | OK |
metrics are OK
check_double (Begins at: 2239 Ends at: 2279)
LOC: | 41 | | OK |
metrics are OK
check_string (Begins at: 2281 Ends at: 2308)
Complexity: | 8 | | OK |
LOC: | 28 | | OK |
metrics are OK
check_required (Begins at: 2310 Ends at: 2333)
LOC: | 24 | | OK |
metrics are OK
split_opts (Begins at: 2335 Ends at: 2398)
LOC: | 64 | | OK |
metrics are OK
check_multiple_opts (Begins at: 2400 Ends at: 2438)
LOC: | 39 | | OK |
metrics are OK
check_overwrite (Begins at: 2441 Ends at: 2497)
Complexity: | 11 | | OK |
LOC: | 57 | | OK |
metrics are OK
interactive (Begins at: 2499 Ends at: 2527)
LOC: | 29 | | OK |
metrics are OK
interactive_flag (Begins at: 2529 Ends at: 2537)
LOC: | 9 | | OK |
metrics are OK
interactive_option (Begins at: 2539 Ends at: 2629)
Complexity: | 23 | * | |
CalledNBR: | 41 | * | |
LOC: | 91 | | OK |
metrics are OK
split_gisprompt (Begins at: 2631 Ends at: 2661)
LOC: | 31 | | OK |
metrics are OK
gis_prompt (Begins at: 2663 Ends at: 2720)
CalledNBR: | 20 | | OK |
LOC: | 58 | | OK |
metrics are OK
G_recreate_command (Begins at: 2722 Ends at: 2824)
CalledNBR: | 25 | | OK |
LOC: | 103 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-08-08 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
