[GRASS-QA] GRASS QA: carlos |
./grass6/vector/v.lrs/v.lrs.where/main.c |no clones | 0
monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Aug 10 10:46:11 EDT 2007
Hello carlos,
ANALYSIS
vector/v.lrs/v.lrs.where/main.c functions
main (Begins at: 35 Ends at: 202)
Complexity: | 14 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 74 | ** | Warning |
LOC: | 168 | * | |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-08-10 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
