[GRASS-QA] GRASS QA: carlos | ./grass6/vector/v.out.svg/main.c |no
	clones | 1 monsters | 1 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Fri Aug 10 10:46:11 EDT 2007
Hello carlos,
ANALYSIS
vector/v.out.svg/main.c functions
main (Begins at: 41 Ends at: 307)
Complexity:   |      24 |     * |         |
CalledNBR:    |     119 |   *** | MONSTER |
LOC:          |     267 |    ** | Warning |
1 metric are OUT OF RANGE!
mk_path (Begins at: 310 Ends at: 327)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
mk_attribs (Begins at: 330 Ends at: 375)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      20 |       |      OK |
LOC:          |      46 |       |      OK |
at least 1 values are close to an outlier please consider revising code
print_escaped_for_xml (Begins at: 378 Ends at: 398)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-10 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
