[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.in.mat/main.c |no clones | 3 monsters | 0 warnings
Fri Aug 10 10:53:14 EDT 2007
Hello carlos,
ANALYSIS
raster/r.in.mat/main.c functions
main (Begins at: 48 Ends at: 463)
Complexity:   |      59 |   *** | MONSTER |
CalledNBR:    |     159 |   *** | MONSTER |
LOC:          |     416 |   *** | MONSTER |
3 metric are OUT OF RANGE!
is_nan (Begins at: 467 Ends at: 500)
Complexity:   |       9 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-10 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
