[GRASS-QA] GRASS QA: paul | ./grass6/general/g.proj/datumtrans.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Aug 14 16:18:17 EDT 2007
Hello paul,
ANALYSIS
general/g.proj/datumtrans.c functions
set_datumtrans (Begins at: 43 Ends at: 167)
Complexity: | 15 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 23 | | OK |
LOC: | 125 | * | |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-08-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
