[GRASS-QA] GRASS QA: paul | ./grass6/lib/gis/parser.c |no clones |
2 monsters | 6 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Aug 14 16:35:35 EDT 2007
Hello paul,
ANALYSIS
lib/gis/parser.c functions
G_disable_interactive (Begins at: 162 Ends at: 183)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 22 | | OK |
metrics are OK
G_define_flag (Begins at: 186 Ends at: 244)
Complexity: | 3 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 59 | | OK |
metrics are OK
G_define_option (Begins at: 247 Ends at: 329)
LOC: | 83 | | OK |
metrics are OK
G_define_standard_option (Begins at: 332 Ends at: 603)
Complexity: | 31 | ** | Warning |
CalledNBR: | 36 | * | |
LOC: | 272 | *** | MONSTER |
at least 2 values are close to an outlier please consider revising code
G_define_module (Begins at: 606 Ends at: 658)
CalledNBR: | 1 | | OK |
LOC: | 53 | | OK |
metrics are OK
G_parser (Begins at: 660 Ends at: 929)
Complexity: | 38 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 78 | ** | Warning |
LOC: | 270 | ** | Warning |
1 metric are OUT OF RANGE!
uses_new_gisprompt (Begins at: 932 Ends at: 982)
Complexity: | 5 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 51 | | OK |
metrics are OK
G_usage (Begins at: 984 Ends at: 1170)
Complexity: | 33 | ** | Warning |
CalledNBR: | 53 | * | |
LOC: | 187 | * | |
at least 1 values are close to an outlier please consider revising code
print_escaped_for_xml (Begins at: 1172 Ends at: 1188)
Complexity: | 6 | | OK |
LOC: | 17 | | OK |
metrics are OK
print_escaped_for_html (Begins at: 1195 Ends at: 1206)
Complexity: | 7 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 12 | | OK |
metrics are OK
G_usage_xml (Begins at: 1209 Ends at: 1423)
Complexity: | 28 | ** | Warning |
CalledNBR: | 71 | ** | Warning |
LOC: | 215 | ** | Warning |
at least 3 values are close to an outlier please consider revising code
G_usage_html (Begins at: 1425 Ends at: 1650)
Complexity: | 42 | *** | MONSTER |
CalledNBR: | 85 | ** | Warning |
LOC: | 226 | ** | Warning |
G_script (Begins at: 1652 Ends at: 1763)
Complexity: | 22 | * | |
CalledNBR: | 46 | * | |
LOC: | 112 | | OK |
metrics are OK
generate_tcl (Begins at: 1765 Ends at: 1860)
Complexity: | 10 | | OK |
CalledNBR: | 45 | * | |
LOC: | 96 | | OK |
metrics are OK
G_gui_tcltk (Begins at: 1863 Ends at: 1892)
CalledNBR: | 8 | | OK |
LOC: | 30 | | OK |
metrics are OK
G_gui_wx (Begins at: 1895 Ends at: 1906)
LOC: | 12 | | OK |
metrics are OK
G_gui (Begins at: 1909 Ends at: 1917)
Complexity: | 2 | | OK |
LOC: | 9 | | OK |
metrics are OK
G_tcltk (Begins at: 1920 Ends at: 1935)
LOC: | 16 | | OK |
metrics are OK
show_options (Begins at: 1937 Ends at: 1967)
Complexity: | 4 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 31 | | OK |
metrics are OK
show (Begins at: 1969 Ends at: 1982)
CalledNBR: | 3 | | OK |
LOC: | 14 | | OK |
metrics are OK
set_flag (Begins at: 1984 Ends at: 2011)
LOC: | 28 | | OK |
metrics are OK
contains (Begins at: 2016 Ends at: 2025)
LOC: | 10 | | OK |
metrics are OK
set_option (Begins at: 2027 Ends at: 2087)
CalledNBR: | 13 | | OK |
LOC: | 61 | | OK |
metrics are OK
check_opts (Begins at: 2089 Ends at: 2126)
LOC: | 38 | | OK |
metrics are OK
check_an_opt (Begins at: 2128 Ends at: 2170)
ParamNBR: | 4 | | OK |
LOC: | 43 | | OK |
metrics are OK
check_int (Begins at: 2172 Ends at: 2238)
Complexity: | 13 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 67 | | OK |
metrics are OK
check_double (Begins at: 2240 Ends at: 2280)
LOC: | 41 | | OK |
metrics are OK
check_string (Begins at: 2282 Ends at: 2309)
Complexity: | 8 | | OK |
LOC: | 28 | | OK |
metrics are OK
check_required (Begins at: 2311 Ends at: 2334)
LOC: | 24 | | OK |
metrics are OK
split_opts (Begins at: 2336 Ends at: 2399)
LOC: | 64 | | OK |
metrics are OK
check_multiple_opts (Begins at: 2401 Ends at: 2439)
LOC: | 39 | | OK |
metrics are OK
check_overwrite (Begins at: 2442 Ends at: 2498)
Complexity: | 11 | | OK |
LOC: | 57 | | OK |
metrics are OK
interactive (Begins at: 2500 Ends at: 2528)
LOC: | 29 | | OK |
metrics are OK
interactive_flag (Begins at: 2530 Ends at: 2538)
LOC: | 9 | | OK |
metrics are OK
interactive_option (Begins at: 2540 Ends at: 2630)
Complexity: | 23 | * | |
CalledNBR: | 41 | * | |
LOC: | 91 | | OK |
metrics are OK
split_gisprompt (Begins at: 2632 Ends at: 2662)
LOC: | 31 | | OK |
metrics are OK
gis_prompt (Begins at: 2664 Ends at: 2721)
CalledNBR: | 20 | | OK |
LOC: | 58 | | OK |
metrics are OK
G_recreate_command (Begins at: 2723 Ends at: 2825)
CalledNBR: | 25 | | OK |
LOC: | 103 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-08-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
