[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.nviz/main.c |1
clones ( main.c )| 2 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 15 12:14:25 EDT 2007
Hello glynn,
ANALYSIS
display/d.nviz/main.c functions
main (Begins at: 43 Ends at: 401)
Complexity: | 26 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 161 | *** | MONSTER |
LOC: | 359 | *** | MONSTER |
2 metric are OUT OF RANGE!
do_profile (Begins at: 408 Ends at: 477)
Complexity: | 10 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 29 | | OK |
LOC: | 70 | | OK |
at least 1 values are close to an outlier please consider revising code
move (Begins at: 480 Ends at: 485)
Complexity: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 6 | | OK |
metrics are OK
cont (Begins at: 487 Ends at: 508)
Complexity: | 5 | | OK |
LOC: | 22 | | OK |
metrics are OK
read_rast (Begins at: 515 Ends at: 618)
Complexity: | 15 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 24 | | OK |
LOC: | 104 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
cont
In display/d.nviz/main.c clones of cont are:
raster/r.profile/main.c cont
Threshold GRASS6 key metrics values at 2007-08-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
