[GRASS-QA] GRASS QA: hamish | ./grass6/visualization/xganim/main.c |no clones | 0 monsters | 1 warnings
Sun Aug 19 23:59:04 EDT 2007
Hello hamish,
ANALYSIS
visualization/xganim/main.c functions
main (Begins at: 68 Ends at: 266)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      47 |     * |         |
LOC:          |     199 |    ** | Warning |
at least 1 values are close to an outlier please consider revising code
load_files (Begins at: 269 Ends at: 401)
Complexity:   |      13 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |      42 |     * |         |
LOC:          |     133 |     * |         |
metrics are OK
do_run (Begins at: 405 Ends at: 487)
Complexity:   |      14 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      83 |       |      OK |
metrics are OK
gee_wildfiles (Begins at: 491 Ends at: 535)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      18 |       |      OK |
LOC:          |      45 |       |      OK |
metrics are OK
change_label (Begins at: 541 Ends at: 550)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
parse_command (Begins at: 554 Ends at: 599)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      13 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-19 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
