[GRASS-QA] GRASS QA: markus | ./grass6/raster3d/r3.gwflow/main.c
|no clones | 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 22 03:11:24 EDT 2007
Hello markus,
ANALYSIS
raster3d/r3.gwflow/main.c functions
set_params (Begins at: 48 Ends at: 145)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 29 | | OK |
LOC: | 98 | | OK |
metrics are OK
main (Begins at: 150 Ends at: 353)
Complexity: | 25 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 89 | *** | MONSTER |
LOC: | 204 | ** | Warning |
1 metric are OUT OF RANGE!
write_result (Begins at: 360 Ends at: 425)
Complexity: | 11 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 20 | | OK |
LOC: | 66 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-08-22 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
