[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.thin/io.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 22 12:29:26 EDT 2007
Hello carlos,
ANALYSIS
raster/r.thin/io.c functions
get_a_row (Begins at: 56 Ends at: 61)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 6 | | OK |
metrics are OK
put_a_row (Begins at: 63 Ends at: 69)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
LOC: | 7 | | OK |
metrics are OK
read_row (Begins at: 72 Ends at: 76)
ParamNBR: | 4 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 5 | | OK |
metrics are OK
write_row (Begins at: 78 Ends at: 82)
LOC: | 5 | | OK |
metrics are OK
open_file (Begins at: 84 Ends at: 164)
Complexity: | 8 | | OK |
CalledNBR: | 41 | * | |
LOC: | 81 | | OK |
metrics are OK
close_file (Begins at: 167 Ends at: 201)
Complexity: | 3 | | OK |
CalledNBR: | 19 | | OK |
LOC: | 35 | | OK |
metrics are OK
map_size (Begins at: 204 Ends at: 211)
ParamNBR: | 3 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 8 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-08-22 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
