[GRASS-QA] GRASS QA: carlos |
./grass6/display/d.profile/ExtractProf.c |no clones | 1
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 22 12:29:25 EDT 2007
Hello carlos,
ANALYSIS
display/d.profile/ExtractProf.c functions
ExtractProfile (Begins at: 48 Ends at: 320)
Complexity: | 33 | ** | Warning |
ParamNBR: | 3 | | OK |
CalledNBR: | 33 | | OK |
LOC: | 273 | *** | MONSTER |
1 metric are OUT OF RANGE!
ucat_max (Begins at: 322 Ends at: 345)
Complexity: | 11 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 24 | | OK |
metrics are OK
ucat_min (Begins at: 348 Ends at: 368)
Complexity: | 8 | | OK |
LOC: | 21 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-08-22 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
