[GRASS-QA] GRASS QA: carlos | ./grass6/imagery/i.class/main.c |no clones | 0 monsters | 0 warnings
Wed Aug 22 12:29:26 EDT 2007
Hello carlos,
ANALYSIS
imagery/i.class/main.c functions
main (Begins at: 36 Ends at: 134)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      45 |     * |         |
LOC:          |      99 |       |      OK |
metrics are OK
quit (Begins at: 137 Ends at: 144)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
error (Begins at: 147 Ends at: 175)
Complexity:   |       3 |       |      OK |
CalledNBR:    |      15 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
check_files (Begins at: 178 Ends at: 242)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      36 |     * |         |
LOC:          |      65 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-22 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
