[GRASS-QA] GRASS QA: markus | ./grass6/display/d.nviz/main.c |1 clones ( main.c )| 2 monsters | 1 warnings
Wed Aug 22 14:27:46 EDT 2007
Hello markus,
ANALYSIS
display/d.nviz/main.c functions
main (Begins at: 43 Ends at: 401)
Complexity:   |      26 |    ** | Warning |
CalledNBR:    |     161 |   *** | MONSTER |
LOC:          |     359 |   *** | MONSTER |
2 metric are OUT OF RANGE!
do_profile (Begins at: 408 Ends at: 477)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      29 |       |      OK |
LOC:          |      70 |       |      OK |
at least 1 values are close to an outlier please consider revising code
move (Begins at: 480 Ends at: 485)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
cont (Begins at: 487 Ends at: 508)
Complexity:   |       5 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
read_rast (Begins at: 515 Ends at: 618)
Complexity:   |      15 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      24 |       |      OK |
LOC:          |     104 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  cont
In display/d.nviz/main.c clones of  cont are:
	raster/r.profile/main.c  cont
Threshold GRASS6 key metrics values at 2007-08-22 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
