[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.li/r.li.daemon/daemon.c |no clones | 2 monsters | 0 warnings
Wed Aug 22 14:38:02 EDT 2007
Hello markus,
ANALYSIS
raster/r.li/r.li.daemon/daemon.c functions
calculateIndex (Begins at: 37 Ends at: 270)
Complexity:   |      31 |    ** | Warning |
ParamNBR:     |       9 |   *** | MONSTER |
CalledNBR:    |      93 |   *** | MONSTER |
LOC:          |     234 |    ** | Warning |
1 metric are OUT OF RANGE!
parseSetup (Begins at: 272 Ends at: 451)
Complexity:   |      16 |     * |         |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |     106 |   *** | MONSTER |
LOC:          |     180 |     * |         |
disposeAreas (Begins at: 453 Ends at: 578)
Complexity:   |      15 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      42 |     * |         |
LOC:          |     126 |     * |         |
metrics are OK
next_Area (Begins at: 580 Ends at: 595)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
print_Output (Begins at: 597 Ends at: 610)
LOC:          |      14 |       |      OK |
metrics are OK
error_Output (Begins at: 612 Ends at: 623)
CalledNBR:    |       4 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
raster_Output (Begins at: 625 Ends at: 636)
LOC:          |      12 |       |      OK |
metrics are OK
write_raster (Begins at: 637 Ends at: 667)
Complexity:   |       2 |       |      OK |
CalledNBR:    |      15 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-22 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
