[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.extrude/main.c |no clones | 3 monsters | 0 warnings
Fri Aug 24 09:29:27 EDT 2007
Hello markus,
ANALYSIS
vector/v.extrude/main.c functions
main (Begins at: 37 Ends at: 342)
Complexity:   |      35 |    ** | Warning |
CalledNBR:    |     110 |   *** | MONSTER |
LOC:          |     306 |   *** | MONSTER |
2 metric are OUT OF RANGE!
extrude (Begins at: 348 Ends at: 434)
Complexity:   |       7 |       |      OK |
ParamNBR:     |      10 |   *** | MONSTER |
CalledNBR:    |      13 |       |      OK |
LOC:          |      87 |       |      OK |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-24 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
