Hello brad,
ANALYSIS
imagery/i.fft/orig_wind.c functions
put_orig_window (Begins at: 9 Ends at: 20)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 12 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
get_orig_window
In imagery/i.fft/orig_wind.c clones of get_orig_window are:
imagery/i.ifft/orig_wind.c get_orig_window
Threshold GRASS6 key metrics values at 2007-08-24 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
