[GRASS-QA] GRASS QA: brad | ./grass6/lib/gmath/max_pow2.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Aug 25 00:00:37 EDT 2007
Hello brad,
ANALYSIS
lib/gmath/max_pow2.c functions
G_math_max_pow2 (Begins at: 16 Ends at: 42)
Complexity: | 3 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 27 | | OK |
metrics are OK
G_math_min_pow2 (Begins at: 44 Ends at: 57)
Complexity: | 2 | | OK |
LOC: | 14 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-08-24 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
