[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.surf.gauss/gaussurf.c |no clones | 0 monsters | 0 warnings
Sat Aug 25 19:01:31 EDT 2007
Hello brad,
ANALYSIS
raster/r.surf.gauss/gaussurf.c functions
gaussurf (Begins at: 12 Ends at: 63)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      52 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-25 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
