[GRASS-QA] GRASS QA: soeren | ./grass6/lib/gmath/ialloc.c |no clones | 0 monsters | 0 warnings
Sat Aug 25 20:21:45 EDT 2007
Hello soeren,
ANALYSIS
lib/gmath/ialloc.c functions
G_alloc_ivector (Begins at: 40 Ends at: 55)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
G_alloc_imatrix (Begins at: 57 Ends at: 78)
CalledNBR:    |       2 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
G_free_ivector (Begins at: 80 Ends at: 96)
LOC:          |      17 |       |      OK |
metrics are OK
G_free_imatrix (Begins at: 98 Ends at: 105)
LOC:          |       8 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-25 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
