[GRASS-QA] GRASS QA: hamish | ./grass6/ps/ps.map/r_vpoints.c |no
clones | 0 monsters | 3 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Aug 27 03:10:40 EDT 2007
Hello hamish,
ANALYSIS
ps/ps.map/r_vpoints.c functions
read_vpoints (Begins at: 42 Ends at: 301)
Complexity: | 37 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 80 | ** | Warning |
LOC: | 260 | ** | Warning |
at least 3 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-08-27 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
