[GRASS-QA] GRASS QA: brad |
./grass6/db/drivers/sqlite/create_table.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 29 03:05:02 EDT 2007
Hello brad,
ANALYSIS
db/drivers/sqlite/create_table.c functions
db__driver_create_table (Begins at: 29 Ends at: 122)
Complexity: | 18 | * | |
ParamNBR: | 1 | | OK |
CalledNBR: | 42 | * | |
LOC: | 94 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-08-29 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
