[GRASS-QA] GRASS QA: brad | ./grass6/lib/init/set_data.c |no clones | 0 monsters | 3 warnings
Wed Aug 29 03:05:03 EDT 2007
Hello brad,
ANALYSIS
lib/init/set_data.c functions
main (Begins at: 53 Ends at: 272)
Complexity:   |      27 |    ** | Warning |
CalledNBR:    |      87 |   *** | MONSTER |
LOC:          |     220 |    ** | Warning |
at least 3 values are close to an outlier please consider revising code
list_locations (Begins at: 275 Ends at: 282)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
list_mapsets (Begins at: 285 Ends at: 326)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      42 |       |      OK |
metrics are OK
first_word (Begins at: 329 Ends at: 338)
CalledNBR:    |       2 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
hit_return (Begins at: 341 Ends at: 349)
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-29 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
