[GRASS-QA] GRASS QA: brad | ./grass6/db/drivers/sqlite/db.c |1
clones ( db.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 29 03:08:15 EDT 2007
Hello brad,
ANALYSIS
db/drivers/sqlite/db.c functions
db__driver_open_database (Begins at: 31 Ends at: 105)
Complexity: | 6 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 26 | | OK |
LOC: | 75 | | OK |
metrics are OK
db__driver_close_database (Begins at: 107 Ends at: 115)
Complexity: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In db/drivers/sqlite/db.c clones of db__driver_close_database are:
lib/D/Dscreen.c Dscreen
Threshold GRASS6 key metrics values at 2007-08-29 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
