[GRASS-QA] GRASS QA: brad | ./grass6/gem/reg_html.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 29 05:58:04 EDT 2007
Hello brad,
ANALYSIS
gem/reg_html.c functions
new_ext_html (Begins at: 28 Ends at: 98)
Complexity: | 8 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 24 | | OK |
LOC: | 71 | | OK |
metrics are OK
delete_ext_html (Begins at: 101 Ends at: 152)
Complexity: | 7 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 52 | | OK |
metrics are OK
register_html (Begins at: 155 Ends at: 247)
Complexity: | 9 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 31 | | OK |
LOC: | 93 | | OK |
metrics are OK
deregister_html (Begins at: 250 Ends at: 341)
ParamNBR: | 2 | | OK |
LOC: | 92 | | OK |
metrics are OK
restore_html (Begins at: 347 Ends at: 515)
Complexity: | 20 | * | |
ParamNBR: | 1 | | OK |
CalledNBR: | 55 | * | |
LOC: | 169 | * | |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-08-29 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
