[GRASS-QA] GRASS QA: brad | ./grass6/gem/reg_deps.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 29 05:58:03 EDT 2007
Hello brad,
ANALYSIS
gem/reg_deps.c functions
depstr (Begins at: 31 Ends at: 74)
Complexity: | 7 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 16 | | OK |
LOC: | 44 | | OK |
metrics are OK
register_extension (Begins at: 82 Ends at: 210)
Complexity: | 16 | * | |
ParamNBR: | 6 | * | |
CalledNBR: | 41 | * | |
LOC: | 129 | * | |
metrics are OK
deregister_extension (Begins at: 216 Ends at: 302)
Complexity: | 13 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 25 | | OK |
LOC: | 87 | | OK |
metrics are OK
check_dependencies (Begins at: 310 Ends at: 413)
Complexity: | 17 | * | |
CalledNBR: | 29 | | OK |
LOC: | 104 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-08-29 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
