[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.texture/h_measure.c |no clones | 1 monsters | 0 warnings
Wed Aug 29 06:32:28 EDT 2007
Hello brad,
ANALYSIS
raster/r.texture/h_measure.c functions
h_measure (Begins at: 68 Ends at: 249)
Complexity:   |      72 |   *** | MONSTER |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      65 |    ** | Warning |
LOC:          |     182 |     * |         |
1 metric are OUT OF RANGE!
MatrixDealloc (Begins at: 251 Ends at: 256)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
f1_asm (Begins at: 258 Ends at: 277)
CalledNBR:    |       0 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
f2_contrast (Begins at: 281 Ends at: 305)
Complexity:   |       2 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
f3_corr (Begins at: 308 Ends at: 354)
LOC:          |      47 |       |      OK |
metrics are OK
f4_var (Begins at: 358 Ends at: 378)
LOC:          |      21 |       |      OK |
metrics are OK
f5_idm (Begins at: 381 Ends at: 393)
LOC:          |      13 |       |      OK |
metrics are OK
f6_savg (Begins at: 398 Ends at: 416)
LOC:          |      19 |       |      OK |
metrics are OK
f7_svar (Begins at: 420 Ends at: 439)
ParamNBR:     |       3 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
f8_sentropy (Begins at: 442 Ends at: 461)
CalledNBR:    |       1 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
f9_entropy (Begins at: 465 Ends at: 477)
LOC:          |      13 |       |      OK |
metrics are OK
f10_dvar (Begins at: 481 Ends at: 506)
LOC:          |      26 |       |      OK |
metrics are OK
f11_dentropy (Begins at: 509 Ends at: 528)
LOC:          |      20 |       |      OK |
metrics are OK
f12_icorr (Begins at: 531 Ends at: 571)
CalledNBR:    |       7 |       |      OK |
LOC:          |      41 |       |      OK |
metrics are OK
f13_icorr (Begins at: 574 Ends at: 614)
CalledNBR:    |      10 |       |      OK |
LOC:          |      41 |       |      OK |
metrics are OK
f14_maxcorr (Begins at: 617 Ends at: 666)
CalledNBR:    |       9 |       |      OK |
LOC:          |      50 |       |      OK |
metrics are OK
vector (Begins at: 669 Ends at: 677)
CalledNBR:    |       4 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
matrix (Begins at: 681 Ends at: 700)
ParamNBR:     |       4 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
simplesrt (Begins at: 703 Ends at: 719)
LOC:          |      17 |       |      OK |
metrics are OK
mkbalanced (Begins at: 722 Ends at: 769)
Complexity:   |       7 |       |      OK |
LOC:          |      48 |       |      OK |
metrics are OK
reduction (Begins at: 773 Ends at: 814)
Complexity:   |       5 |       |      OK |
LOC:          |      42 |       |      OK |
metrics are OK
hessenberg (Begins at: 817 Ends at: 974)
Complexity:   |      22 |     * |         |
CalledNBR:    |      31 |       |      OK |
LOC:          |     158 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-29 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
