[GRASS-QA] GRASS QA: brad | ./grass6/raster/simwe/simlib/input.c
|no clones | 3 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 29 22:20:34 EDT 2007
Hello brad,
ANALYSIS
raster/simwe/simlib/input.c functions
input_data (Begins at: 25 Ends at: 402)
Complexity: | 80 | *** | MONSTER |
ParamNBR: | 1 | | OK |
CalledNBR: | 128 | *** | MONSTER |
LOC: | 378 | *** | MONSTER |
3 metric are OUT OF RANGE!
grad_check (Begins at: 406 Ends at: 626)
Complexity: | 25 | * | |
CalledNBR: | 37 | * | |
LOC: | 221 | ** | Warning |
at least 1 values are close to an outlier please consider revising code
amax1 (Begins at: 629 Ends at: 641)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 13 | | OK |
metrics are OK
amin1 (Begins at: 644 Ends at: 656)
LOC: | 13 | | OK |
metrics are OK
min (Begins at: 659 Ends at: 673)
LOC: | 15 | | OK |
metrics are OK
max (Begins at: 676 Ends at: 688)
LOC: | 13 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-08-29 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
