[GRASS-QA] GRASS QA: brad | ./grass6/vector/v.voronoi/sw_geometry.c |no clones | 0 monsters | 0 warnings
Wed Aug 29 22:28:36 EDT 2007
Hello brad,
ANALYSIS
vector/v.voronoi/sw_geometry.c functions
geominit (Begins at: 5 Ends at: 19)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
bisect (Begins at: 22 Ends at: 50)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
intersect (Begins at: 53 Ends at: 88)
Complexity:   |       6 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      36 |       |      OK |
metrics are OK
right_of (Begins at: 91 Ends at: 132)
Complexity:   |       9 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      42 |       |      OK |
metrics are OK
endpoint (Begins at: 136 Ends at: 147)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
dist (Begins at: 149 Ends at: 155)
LOC:          |       7 |       |      OK |
metrics are OK
makevertex (Begins at: 157 Ends at: 163)
LOC:          |       7 |       |      OK |
metrics are OK
deref (Begins at: 166 Ends at: 171)
LOC:          |       6 |       |      OK |
metrics are OK
ref (Begins at: 173 Ends at: 177)
LOC:          |       5 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-29 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
