[GRASS-QA] GRASS QA: brad |
./grass6/vector/lidar/v.lidar.edgedetection/main.c |no clones
| 2 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 29 22:35:43 EDT 2007
Hello brad,
ANALYSIS
vector/lidar/v.lidar.edgedetection/main.c functions
main (Begins at: 44 Ends at: 354)
Complexity: | 22 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 138 | *** | MONSTER |
LOC: | 311 | *** | MONSTER |
2 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-08-29 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
