[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.to.db/parse.c |no clones | 0 monsters | 0 warnings
Sun Dec 2 08:09:31 EST 2007
Hello markus,
ANALYSIS
vector/v.to.db/parse.c functions
parse_command_line (Begins at: 12 Ends at: 161)
Complexity:   |      12 |       |      OK |
CalledNBR:    |      43 |     * |         |
LOC:          |     150 |     * |         |
metrics are OK
parse_units (Begins at: 163 Ends at: 175)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
parse_option (Begins at: 177 Ends at: 195)
Complexity:   |      13 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
match (Begins at: 198 Ends at: 206)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-12-02 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
