[GRASS-QA] GRASS QA: markus | ./grass6/lib/display/draw2.c |11
clones ( draw2.c )| 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Dec 3 09:45:27 EST 2007
Hello markus,
ANALYSIS
lib/display/draw2.c functions
alloc_int (Begins at: 79 Ends at: 88)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 10 | | OK |
metrics are OK
alloc_float (Begins at: 90 Ends at: 99)
LOC: | 10 | | OK |
metrics are OK
dealloc_float (Begins at: 101 Ends at: 116)
ParamNBR: | 3 | | OK |
LOC: | 16 | | OK |
metrics are OK
do_convert (Begins at: 118 Ends at: 129)
Complexity: | 1 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 12 | | OK |
metrics are OK
dist_plane (Begins at: 131 Ends at: 134)
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
interpolate (Begins at: 136 Ends at: 139)
ParamNBR: | 4 | | OK |
LOC: | 4 | | OK |
metrics are OK
clip_plane (Begins at: 141 Ends at: 173)
Complexity: | 4 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 33 | | OK |
metrics are OK
do_clip (Begins at: 175 Ends at: 198)
Complexity: | 9 | | OK |
ParamNBR: | 2 | | OK |
LOC: | 24 | | OK |
metrics are OK
shift_count (Begins at: 200 Ends at: 203)
CalledNBR: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
shift_angle (Begins at: 205 Ends at: 208)
LOC: | 4 | | OK |
metrics are OK
coerce (Begins at: 210 Ends at: 216)
LOC: | 7 | | OK |
metrics are OK
euclidify (Begins at: 218 Ends at: 248)
Complexity: | 3 | | OK |
LOC: | 31 | | OK |
metrics are OK
do_ll_wrap (Begins at: 250 Ends at: 281)
ParamNBR: | 7 | ** | Warning |
LOC: | 32 | | OK |
at least 1 values are close to an outlier please consider revising code
D_set_clip (Begins at: 283 Ends at: 311)
LOC: | 29 | | OK |
metrics are OK
D_set_clip_margin (Begins at: 313 Ends at: 326)
LOC: | 14 | | OK |
metrics are OK
D_clip_to_map (Begins at: 328 Ends at: 347)
LOC: | 20 | | OK |
metrics are OK
D_move_clip (Begins at: 349 Ends at: 368)
LOC: | 20 | | OK |
metrics are OK
line_clip (Begins at: 370 Ends at: 395)
CalledNBR: | 11 | | OK |
LOC: | 26 | | OK |
metrics are OK
line_clip_ll (Begins at: 397 Ends at: 419)
LOC: | 23 | | OK |
metrics are OK
D_cont_clip (Begins at: 421 Ends at: 437)
LOC: | 17 | | OK |
metrics are OK
D_polydots_clip (Begins at: 439 Ends at: 470)
Complexity: | 5 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 32 | | OK |
metrics are OK
cull_polyline_plane (Begins at: 472 Ends at: 517)
LOC: | 46 | | OK |
metrics are OK
polyline_cull (Begins at: 519 Ends at: 546)
LOC: | 28 | | OK |
metrics are OK
D_polyline_cull (Begins at: 548 Ends at: 560)
LOC: | 13 | | OK |
metrics are OK
polyline_clip (Begins at: 562 Ends at: 568)
LOC: | 7 | | OK |
metrics are OK
D_polyline_clip (Begins at: 570 Ends at: 582)
LOC: | 13 | | OK |
metrics are OK
cull_polygon_plane (Begins at: 584 Ends at: 629)
LOC: | 46 | | OK |
metrics are OK
polygon_cull (Begins at: 631 Ends at: 658)
LOC: | 28 | | OK |
metrics are OK
D_polygon_cull (Begins at: 660 Ends at: 669)
LOC: | 10 | | OK |
metrics are OK
clip_polygon_plane (Begins at: 671 Ends at: 711)
LOC: | 41 | | OK |
metrics are OK
polygon_clip (Begins at: 713 Ends at: 740)
LOC: | 28 | | OK |
metrics are OK
D_polygon_clip (Begins at: 742 Ends at: 751)
LOC: | 10 | | OK |
metrics are OK
box_clip (Begins at: 753 Ends at: 769)
CalledNBR: | 9 | | OK |
LOC: | 17 | | OK |
metrics are OK
box_clip_ll (Begins at: 771 Ends at: 784)
LOC: | 14 | | OK |
metrics are OK
D_box_clip (Begins at: 786 Ends at: 795)
LOC: | 10 | | OK |
metrics are OK
D_move (Begins at: 797 Ends at: 803)
LOC: | 7 | | OK |
metrics are OK
D_cont (Begins at: 805 Ends at: 811)
LOC: | 7 | | OK |
metrics are OK
D_polydots (Begins at: 813 Ends at: 817)
LOC: | 5 | | OK |
metrics are OK
D_polyline (Begins at: 819 Ends at: 823)
LOC: | 5 | | OK |
metrics are OK
D_polygon (Begins at: 825 Ends at: 829)
LOC: | 5 | | OK |
metrics are OK
D_box (Begins at: 831 Ends at: 843)
LOC: | 13 | | OK |
metrics are OK
D_line_width (Begins at: 845 Ends at: 863)
LOC: | 19 | | OK |
metrics are OK
Clone analysis:
This file has 11 potentially cloned functions:
cull_polygon_plane cull_polyline_plane D_polygon_clip D_polygon_cull polygon_clip polygon_cull polyline_cull D_polyline_clip D_polyline_cull D_cont D_move
In lib/display/draw2.c clones of D_polyline_cull are:
lib/display/draw2.c D_polyline_clip
In lib/display/draw2.c clones of D_polyline_clip are:
lib/display/draw2.c D_polyline_cull
In lib/display/draw2.c clones of D_move are:
lib/display/draw2.c D_cont
In lib/display/draw2.c clones of D_cont are:
lib/display/draw2.c D_move
In lib/display/draw2.c clones of polygon_cull are:
lib/display/draw2.c polygon_clip
lib/display/draw2.c polyline_cull
In lib/display/draw2.c clones of D_polygon_clip are:
lib/display/draw2.c D_polygon_cull
In lib/display/draw2.c clones of cull_polygon_plane are:
lib/display/draw2.c cull_polyline_plane
In lib/display/draw2.c clones of cull_polyline_plane are:
lib/display/draw2.c cull_polygon_plane
In lib/display/draw2.c clones of D_polygon_cull are:
lib/display/draw2.c D_polygon_clip
In lib/display/draw2.c clones of polygon_clip are:
lib/display/draw2.c polygon_cull
In lib/display/draw2.c clones of polyline_cull are:
Threshold GRASS6 key metrics values at 2007-12-03 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
