[GRASS-QA] GRASS QA: hamish | ./grass6/lib/gis/verbose.c |no clones | 0 monsters | 0 warnings
Tue Dec 4 04:40:43 EST 2007
Hello hamish,
ANALYSIS
lib/gis/verbose.c functions
G_verbose (Begins at: 44 Ends at: 69)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
G_verbose_max (Begins at: 71 Ends at: 83)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
G_verbose_std (Begins at: 85 Ends at: 97)
LOC:          |      13 |       |      OK |
metrics are OK
G_verbose_min (Begins at: 99 Ends at: 113)
LOC:          |      15 |       |      OK |
metrics are OK
G_set_verbose (Begins at: 115 Ends at: 124)
Complexity:   |       2 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-12-04 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
