[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.distance/main.c |no clones | 3 monsters | 0 warnings
Thu Dec 6 09:21:56 EST 2007
Hello martinl,
ANALYSIS
vector/v.distance/main.c functions
main (Begins at: 68 Ends at: 1040)
Complexity:   |     161 |   *** | MONSTER |
CalledNBR:    |     315 |   *** | MONSTER |
LOC:          |     973 |   *** | MONSTER |
3 metric are OUT OF RANGE!
cmp_near (Begins at: 1043 Ends at: 1050)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
cmp_exist (Begins at: 1053 Ends at: 1061)
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-12-06 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
