[GRASS-QA] GRASS QA: markus | ./grass6/general/g.region/cmd/main.c
	|no clones | 3 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Sat Feb  3 03:59:26 EST 2007
Hello markus,
ANALYSIS
general/g.region/cmd/main.c functions
main (Begins at: 28 Ends at: 767)
Complexity:   |     104 |   *** | MONSTER |
CalledNBR:    |     227 |   *** | MONSTER |
LOC:          |     740 |   *** | MONSTER |
3 metric are OUT OF RANGE!
die (Begins at: 769 Ends at: 775)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
nsew (Begins at: 777 Ends at: 783)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
llinfo (Begins at: 785 Ends at: 793)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-02-03 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
