[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.region/main.c |no clones | 3 monsters | 0 warnings
Sat Feb 3 05:50:12 EST 2007
Hello markus,
ANALYSIS
raster/r.region/main.c functions
main (Begins at: 25 Ends at: 375)
Complexity:   |      58 |   *** | MONSTER |
CalledNBR:    |     118 |   *** | MONSTER |
LOC:          |     351 |   *** | MONSTER |
3 metric are OUT OF RANGE!
die (Begins at: 377 Ends at: 380)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
nsew (Begins at: 382 Ends at: 388)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
llinfo (Begins at: 390 Ends at: 398)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-02-03 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
