[GRASS-QA] GRASS QA: martinl | ./grass6/db/drivers/dbf/column.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Feb 5 05:59:12 EST 2007
Hello martinl,
ANALYSIS
db/drivers/dbf/column.c functions
add_column (Begins at: 26 Ends at: 59)
Complexity: | 3 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 5 | | OK |
LOC: | 34 | | OK |
metrics are OK
find_column (Begins at: 62 Ends at: 72)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 11 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-02-05 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
