[GRASS-QA] GRASS QA: brad | ./grass6/vector/v.to.rast/do_areas.c
|no clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Feb 8 11:55:50 EST 2007
Hello brad,
ANALYSIS
vector/v.to.rast/do_areas.c functions
do_areas (Begins at: 17 Ends at: 72)
Complexity: | 11 | | OK |
ParamNBR: | 8 | ** | Warning |
CalledNBR: | 18 | | OK |
LOC: | 56 | | OK |
at least 1 values are close to an outlier please consider revising code
sort_areas (Begins at: 74 Ends at: 115)
Complexity: | 4 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 42 | | OK |
metrics are OK
compare (Begins at: 117 Ends at: 125)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-02-08 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
