[GRASS-QA] GRASS QA: jachym | ./grass6/vector/v.to.rast/support.c
|2 clones ( support.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Feb 10 11:29:54 EST 2007
Hello jachym,
ANALYSIS
vector/v.to.rast/support.c functions
update_hist (Begins at: 12 Ends at: 43)
Complexity: | 3 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 32 | | OK |
metrics are OK
update_colors (Begins at: 46 Ends at: 58)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 13 | | OK |
metrics are OK
update_fcolors (Begins at: 62 Ends at: 74)
LOC: | 13 | | OK |
metrics are OK
update_cats (Begins at: 78 Ends at: 90)
ParamNBR: | 3 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 13 | | OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
update_fcolors update_colors
In vector/v.to.rast/support.c clones of update_colors are:
vector/v.to.rast/support.c update_fcolors
In vector/v.to.rast/support.c clones of update_fcolors are:
vector/v.to.rast/support.c update_colors
Threshold GRASS6 key metrics values at 2007-02-10 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
