[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.in.dxf/layer_list.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Feb 11 06:48:00 EST 2007
Hello markus,
ANALYSIS
vector/v.in.dxf/layer_list.c functions
add_layer_to_list (Begins at: 4 Ends at: 14)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 11 | | OK |
metrics are OK
is_layer_in_list (Begins at: 16 Ends at: 28)
Complexity: | 3 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 13 | | OK |
metrics are OK
init_list (Begins at: 30 Ends at: 47)
CalledNBR: | 2 | | OK |
LOC: | 18 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-02-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
