[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.mapgraph/do_graph.c |no clones | 0 monsters | 0 warnings
Sun Feb 11 15:37:15 EST 2007
Hello glynn,
ANALYSIS
display/d.mapgraph/do_graph.c functions
set_text_size (Begins at: 22 Ends at: 33)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
do_draw (Begins at: 35 Ends at: 51)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
do_move (Begins at: 53 Ends at: 67)
CalledNBR:    |       2 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
do_icon (Begins at: 69 Ends at: 110)
Complexity:   |       9 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      42 |       |      OK |
metrics are OK
do_color (Begins at: 112 Ends at: 136)
Complexity:   |       4 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
do_poly (Begins at: 138 Ends at: 176)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
do_size (Begins at: 178 Ends at: 188)
LOC:          |      11 |       |      OK |
metrics are OK
do_text (Begins at: 190 Ends at: 210)
CalledNBR:    |       5 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
check_alloc (Begins at: 212 Ends at: 237)
CalledNBR:    |       4 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
scan_en (Begins at: 239 Ends at: 252)
ParamNBR:     |       4 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-02-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
