[GRASS-QA] GRASS QA: glynn | ./grass6/display/drivers/XDRIVER/main.c |1 clones ( Color_table.c main.c )| 0 monsters | 0 warnings
Sun Feb 11 15:37:16 EST 2007
Hello glynn,
ANALYSIS
display/drivers/XDRIVER/main.c functions
main (Begins at: 5 Ends at: 44)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      40 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  main
In display/drivers/XDRIVER/main.c clones of  main are:
	display/drivers/PNG/main.c  main
Threshold GRASS6 key metrics values at 2007-02-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
