[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/common.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Feb 11 16:58:05 EST 2007
Hello glynn,
ANALYSIS
lib/raster/common.c functions
R_flush (Begins at: 17 Ends at: 20)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
R_set_update_function (Begins at: 31 Ends at: 42)
ParamNBR: | 3 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 12 | | OK |
metrics are OK
R_call_update_function (Begins at: 44 Ends at: 48)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
LOC: | 5 | | OK |
metrics are OK
R_has_update_function (Begins at: 56 Ends at: 59)
LOC: | 4 | | OK |
metrics are OK
R_set_cancel (Begins at: 70 Ends at: 73)
LOC: | 4 | | OK |
metrics are OK
R_get_cancel (Begins at: 81 Ends at: 101)
LOC: | 21 | | OK |
metrics are OK
R_raster (Begins at: 103 Ends at: 133)
Complexity: | 3 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 31 | | OK |
metrics are OK
R_pad_perror (Begins at: 135 Ends at: 152)
Complexity: | 10 | | OK |
LOC: | 18 | | OK |
metrics are OK
R_pad_freelist (Begins at: 154 Ends at: 165)
CalledNBR: | 2 | | OK |
LOC: | 12 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-02-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
