[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.vect/zcoor.c |no clones | 0 monsters | 0 warnings
Sun Feb 11 16:58:04 EST 2007
Hello glynn,
ANALYSIS
display/d.vect/zcoor.c functions
zcoor (Begins at: 9 Ends at: 91)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      26 |       |      OK |
LOC:          |      83 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-02-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
