[GRASS-QA] GRASS QA: hamish | ./grass6/lib/gis/verbose.c |no clones
| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Feb 12 02:51:38 EST 2007
Hello hamish,
ANALYSIS
lib/gis/verbose.c functions
G_verbose (Begins at: 39 Ends at: 55)
Complexity: | 4 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 17 | | OK |
metrics are OK
G_verbose_max (Begins at: 62 Ends at: 65)
Complexity: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
G_verbose_min (Begins at: 72 Ends at: 75)
LOC: | 4 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-02-12 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
