[GRASS-QA] GRASS QA: martinl | ./grass6/general/manage/cmd/remove.c
	|no clones | 0 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Mon Feb 12 10:07:47 EST 2007
Hello martinl,
ANALYSIS
general/manage/cmd/remove.c functions
main (Begins at: 9 Ends at: 128)
Complexity:   |      14 |       |      OK |
CalledNBR:    |      39 |     * |         |
LOC:          |     120 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-02-12 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
