[GRASS-QA] GRASS QA: paul | ./grass6/lib/proj/datum.c |no clones |
0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Feb 12 13:52:22 EST 2007
Hello paul,
ANALYSIS
lib/proj/datum.c functions
GPJ_get_datum_by_name (Begins at: 53 Ends at: 99)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 47 | | OK |
metrics are OK
GPJ_get_default_datum_params_by_name (Begins at: 101 Ends at: 152)
CalledNBR: | 4 | | OK |
LOC: | 52 | | OK |
metrics are OK
GPJ_get_datum_params (Begins at: 154 Ends at: 190)
Complexity: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 37 | | OK |
metrics are OK
GPJ__get_datum_params (Begins at: 192 Ends at: 255)
Complexity: | 6 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 20 | | OK |
LOC: | 64 | | OK |
metrics are OK
GPJ_ask_datum_params (Begins at: 257 Ends at: 383)
Complexity: | 14 | | OK |
CalledNBR: | 44 | * | |
LOC: | 127 | * | |
metrics are OK
get_datum_transform_by_name (Begins at: 385 Ends at: 471)
Complexity: | 8 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 23 | | OK |
LOC: | 87 | | OK |
metrics are OK
read_datum_table (Begins at: 473 Ends at: 520)
Complexity: | 5 | | OK |
CalledNBR: | 15 | | OK |
LOC: | 48 | | OK |
metrics are OK
GPJ_free_datum (Begins at: 528 Ends at: 534)
LOC: | 7 | | OK |
metrics are OK
free_datum_list (Begins at: 542 Ends at: 556)
Complexity: | 2 | | OK |
LOC: | 15 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-02-12 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
