[GRASS-QA] GRASS QA: martinl | ./grass6/ps/ps.map/do_plt.c |no clones | 0 monsters | 1 warnings
Mon Jan 8 05:49:34 EST 2007
Hello martinl,
ANALYSIS
ps/ps.map/do_plt.c functions
do_plt (Begins at: 14 Ends at: 177)
Complexity:   |      31 |    ** | Warning |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      44 |     * |         |
LOC:          |     164 |     * |         |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-01-08 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
